Old 03-13-2007, 04:46 PM
SarahMarie SarahMarie is offline
quick question about capacitors....
I have a 91 3000 GT SL Automatic, It has capacitors in the ECU Correct?
(I took my car to the Misiubishi Dealer and he has no Idea what I'm talking about. And I just want to make sure that the automatic has them.)
Thanks for the Help ^^
Old 03-13-2007, 05:18 PM
Hotshot8792 Hotshot8792 is offline
Re: quick question about capacitors....
All ECU's have capacitors in them. The type of transmission of the car does not matter.
Are your capacitors leaking? I know its a problem in the 1st gens, and if you have to replace them, its a cheap fix. 3SX sells them
http://www.3sx.com/store/comersus_vi...?idProduct=755
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 03-15-2007, 07:05 PM
youngcaradvc youngcaradvc is offline
The capacitors in my TCU are leaking (well one is), does 3sx have replacements for those?
Old 03-15-2007, 09:25 PM
AutostradaVR4 AutostradaVR4 is offline
Ah. very different. Yes, only the automatics have TCU.
not sure where you can get replacements, but im pretty sure they're available. im sure someone else will post with the answer to that one.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 03-15-2007, 09:41 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
You can find them locally at some shops that carry electronic gizmos too. If it has already leaked on to the board a bit it may be too late and your board will be fried meaning you need to get it rebuilt or buy a new one. Rebuilt is far cheaper though.
Old 03-15-2007, 11:41 PM
Open up your TCU and look to see what the charge capacity and the voltage rating of the capacitors are. The charge capacity will be in terms of Farads (F). Most likely it will be represented in microfarads (uF). Once you get both, go to a website like www.newark.com and look for the capacitor that you need, then order what you need.
Old 03-15-2007, 11:52 PM
Thanks dude, sorry i kinda jacked this thread but i figured it was easier then starting a new one for basically the same thing, i got 50v47uF and sodering isnt a problem.
