Old 03-13-2007, 04:20 PM
kramnella kramnella is offline
Help w/ Programing keyless Entry
I have a 1999 Grand Prix GT and have purchased a new keyless entry pendant. I have the programming insrtuctions and they fail to work. When I go thru the procedure and get to the point of turning the key from accessory to off and back to accessary quickly this is what I get:
2 chimes, a pause, 3 chimes, a pause, 6 chimes, a pause, 8 chimes
this repeats itself 3 times then stops and when I hold the lock and unlock buttons down for 14 seconds nothing happens.
Does anyone know what is happening here? Some advice would be very helpfull.
Old 03-13-2007, 05:20 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: Help w/ Programing keyless Entry
Do you have the correct remote?
FCC: ABO0204T
Part # 10246215
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 03-14-2007, 04:12 AM
Yes I do, in fact it is new purchased from the Pontiac dealership
Old 03-14-2007, 02:03 PM
Yes I have the correct remote, and it's new
Old 03-14-2007, 03:33 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
After you turn the key acc/off/acc, are you also opening then closing a door before the chimes start? As far as the chimes go, the first two flashes are indicating the type of BCM you have (type 2) and the programming mode you're in (mode 3). These two should be explained in your owners manual. The second two flashes I believe are trouble code(s), and I'm still working on deciphering it for you.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-08-2007, 11:42 PM
abesafab abesafab is offline
My son and I just performed the programming for his remote tonight using these instructions. The first set seemed to work the best. Nothing worked though until he found and replaced a blown fuse in the fuse panel under the hood. It also affected his radio. Good luck.
***Edited by Moderator***
Old 04-09-2007, 12:03 AM
BNaylor's Avatar
BNaylor BNaylor is offline
abesafab,
Please take note that we do not allow posting of GM copyrighted material, therefore your post has been edited to exclude that material.
What we may allow is a recital of material or a FSM/TSB procedure in your own words but the information you posted verbatim clearly appears to be copyrighted GM FSM and/or TSB information obvious by the GM copyright notice contained at the bottom of each document.
Timeslip 08/12/06
AF Community Guidelines
