CD player, Chassis Ground
Ok, I have a question, it relates to the CD player in my BMW, but isn't necessarily car specific.
I just bought a slightly used Alpine CD player. It worked fine when pulled from the other vehicle, but doesn't work in my car. The radio works in my car, but the CD player doesn't work. It shows that it is reading the disc, and it realizes how many tracks are on the disc, but there is no sound. I do not have the CD player installed in the dash, it's just kinda hanging there (for now). Could it be that the CD player needs the chassis ground (screwed into the dash)? Or should I just return the CD player? Thx, -Mike
1991 Eagle Talon TSI - Broken Head removed, block broken, trans in hatch ![]() 1991 Eagle Talon TSI AWD- in pieces 3" exhaust, rebuilt bottom end Project: Assemble the Eagle is underway... and now with AWD 2003 Lancer Evo 1630hp/1593ft lb tq |
Re: CD player, Chassis Ground
ground it and find out but it shouldn't matter. My alpine I've had hanging from the dash several times (the ground was always connected on the wires) but never on the chasis and it worked just fine.
Are you positive it worked and the cd player worked in the other car?
08 Kawasaki Ninja 250R - Plasma Candy Blue 07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD 97 Mitsu Eclipse Spyder GS-T 5 Speed |
Did you make sure all the speaker wires are hooked up correctly? Did you buy and adapter, or hack off the stock wiring harness to connect everything?
'92 3000gt SL Zoom Stage 1 Clutch Quote:
Ya, it should work if its grounded, i have an alpine in my car and what they reccomend is to NOT use the stock power and the stock ground for the headunit. I would run the power wire from the headunit directly to the battery, then ground the cd player out to something metal inside the dash, you dont have to do this, but its how they recomend it and its how ive always done it. And make sure you have the cd player horizontal, because i know mine doesnt like it when its at weird angles...
I'll give it a shot at regrounding... let you know what happens... the factory power is fine in the BMW, I'm not running a huge setup, just stock stuff for now
damn guys... I just figured out what it was... took me all this time f'in around with it to figure it out... and it was simple as hell...
Taken from: http://www.alpine-usa.com/US-en/supp...its_faq07.html Quote:
haha I was close, figured it has to be in the wiring. Nice that you finally figured it out, something like that would bother me a lot.
it did bother me... I knew that the CD player was practically new, and I knew that the radio worked... and the CD player would work (somewhat), it told me how many tracks were on the CD and would count the timing on the CD... it just wouldn't play... it irked me til now... lol...
oh, just an update... I finally got around to fixing it, and that was the problem... just needed to use the remote turn on wire to the factory antenna wire... b/c that turns on the amps.
I took Tue night and tore the whole damn dash out and put it in the right way(now it don't fall out of the dash, lol)... oh and I installed some neons while I was in there (rice, I know), but they were just laying around... figured wth, might as well amuse some kids while I've got it apart
