Old 03-13-2007, 12:19 AM
goongrinch goongrinch is offline
rubber cement in engine oil
some dickhead put rubber cement in my engine oil, should i be worried?
Old 03-13-2007, 02:13 AM
KiwiBacon KiwiBacon is offline
Re: rubber cement in engine oil
Wow, what's the next "____ in engine oil" thread going to be on?
Old 03-13-2007, 03:57 AM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
i think people have exhausted putting things into engine oil.
there will probably come a time where they just open the hood and change the oil for you..
Seatbelts Saved My Life
Old 03-13-2007, 06:32 AM
UncleBob UncleBob is offline
AF -Advisor
as with most "X was put into my engine" question, the answer is "how much X?"
A small amount wont hurt anything. A large amount (enough to block a decent portion of the oil pick up sump) will cause problems.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 03-13-2007, 10:47 AM
gouldie1903 gouldie1903 is offline
just change the oil
67 chevy c 10 needs paint
01 mustang gt needs hp
Old 03-13-2007, 05:52 PM
MooseNelson's Avatar
MooseNelson MooseNelson is offline
I recently changed the oil pan gasket on my 92 eagle, and got a good look at the oil suction gooseneck that goes down into the bottom of the pan. It has a screen on it so basically anything big won't go up the hose and get lodged in the circulations, however, enough gunk and that screen could get gummed up and make it harder to circulate. I wouldn't worry about it, but just kick his ass for us.
the gasket that was on there before was nothing more than, yep rubber cement gasket maker, so over time that stuff had seeped into my pan anyway, so gasket maker/rubber cement are the same things.
http://www.georides.com
Sub Compacts, Electrics, Biodiesel, hydrogen
