Old 03-12-2007, 10:58 PM
DALE FERGUSON DALE FERGUSON is offline
1991 Chevy Corsica 2.2l
Car runs fine , if it is damp or humidity levels high or it rains out it wants to stall out or idle rough. usally dies or stalls out. it will start up again no problem but it will continue doing the same thing. if it is dry or cold out side the thing runs great.any suggestions?
Old 03-13-2007, 01:35 PM
Steel's Avatar
Steel Steel is offline
Re: 1991 Chevy Corsica 2.2l
If it has a distributor cap, i would check to make sure water isnt getting in there and messing up the spark. Same with the various electrical connectors under the hood, make sure water isnt getting in them somehow.
Old 03-16-2007, 11:51 AM
dkitt10 dkitt10 is offline
haha, uhh good luck!!!
i had the exact same thing on my 91 corsica 4 banger
never did find out what it was, though a mechanic figured somethign to do witht he coils, not sure though
but good luck!
Old 03-26-2007, 03:39 PM
Baracuda645 Baracuda645 is offline
I would check the vacuum lines. If you have a hole or a cracked line, moisture could be getting into the system.
The coils on my 3.1 cavalier had a bad habit of failing. Only one would fail (2 cylinders) and make it run rough. You can take a volt meter and check to each of the coils. A Haynes book has the specs.
just my
Old 04-08-2007, 12:16 PM
E Hagen E Hagen is offline
it sounds like a secondary ignition problem, check wires, plus coils thing like that...
