Old 10-07-2002, 08:34 PM
92PreludeSI 92PreludeSI is offline
Unhappy Speaker help!!
I have a 92 Prelude Si andI just bought some 6 1/2 infinity's to replace my factory rear speakers. everything was fine and dandy and everything sounded great for about 3 weeks. Then i noticed that whenever my bass would hit in my right speaker it would make this weird noise, like a low pitch buzzing noise like a bee was rattling around in my speaker. The rest of the sound quality is really good however. Did i blow the speaker or is it a wiring problem? I have a 200 watt CD unit and it also has to power the other speakers so i dont think i was sending too much power to them. All i know is that my speakers sound like shiznit and i wanna fix it. I have no clue about this stuff. Thanx
Old 10-07-2002, 10:15 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
May want to double check all the connections with that speaker. The Honda factory wiring is not very good, the wire is very thin. You may have a short in the wire, you may want to go to local electronics store and get some new wire and re-wire both of the rear speakers from the HU back. If this is not the problem, it wouldnt hurt to do it anyway with that high power HU and them small stock wires.
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 10-09-2002, 09:01 PM
Duatone Duatone is offline
if youve got that bumble bee sound in your speaker that usually means you've blown it... but check something, if you rev the motor slowly, and the buzz pitch rises along with the rpm's, then youve got interference somewhere, normally a bad ground..but to me its soundsl ike you need to get a new speaker, could just be a defect, check with who you bought them from and see what they can hook you up with
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
