| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
![]() Join Date: May 2006
HV/HP oil pumps need a bigger oil pan?
Im going to be using a HV/HP oil pump and Im wondering how many extra quarts of oil ill need. Will a 5QT pan be enough (+1 for the filter so 6 all together) or do I need a pan with 6qt capacity?
1987 Chevrolet Caprice classic Brougham. 142,000 on the 305 and still chugging
#2 | |
Has a Camaro
Re: HV/HP oil pumps need a bigger oil pan?
if its for a stock or even mid to high perf engine, you dont need an high pr or high volume oil pump, people are brainwashed that it a must have thing if you make over 300hp or something
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
#3 | |
Confoundingly Lucid
I've been running a stock 5qt pan with my HV pump for the last 270,000-odd miles, if that means anything. Then again, I don't rev my engine to 6k, nor do I run a high pressure spring in it.
HV oil pumps are for engines that have increased oil clearances (main, rod & cam bearings, lifter bores etc), high mileage engines, engines designed for sustained high RPM, or engines that have 'leaky' ('variable duration') flat tappets (think of Rhoads lifters for high lift cams that make the engine idle easier). You don't need one in a stock engine. In any case, you will want one for an engine that makes trips above 5k RPM, along with a 6-7 quart pan, or ideally (and expensively), a 22-qt external tank system (also known as a 'dry sump' system).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
#4 | ||
The HV/HP pump Question was for a buddy of mine. So he'll need a 6/7 quart oil pan?
#5 | |
Confoundingly Lucid
Yes, if he's turning high RPMs, above 5,000 on a continuous basis, he will need the larger pan if he doesn't want the bottom end to modify the pan for increased ventilation.
