Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 03-12-2007, 04:31 PM
mastaplaya224 mastaplaya224 is offline
2.0 to 2.4 swapable parts
I have a 99 r/t and am planning on upgrading to a fresh 2.4L crate engine but I'm unsure what performance parts I can successfully swap from the 2.0 to the 2.4.
Old 03-13-2007, 01:10 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 2.0 to 2.4 swapable parts
In the engine, you can use 2.0 cams in a 2.4 but have to figure something out with the camshaft position sensor. You can flip the cam gears around to work on the 2.4 as well. You can't use the crankshaft or pistons.
2003 Dodge SRT-4
Old 03-13-2007, 05:03 PM
Thanks! What about external engine parts like cold air intakes, udp, and pcm?
This is what I'm planning on buying by the way for additional info:
http://www.howellautomotive.com/inde...ROD&ProdID=673
Not sure what "with or without core" means but there she is.
Old 03-14-2007, 08:00 AM
You can use the UDP and PCM, the CAI would depend on what type. May to have "modify" it to work.
2003 Dodge SRT-4
Old 03-14-2007, 08:10 AM
alphalanos alphalanos is offline
with core means you give them your old motor. If you dont give it to them the price might be higher.
96 EJ6. Future home of boosted B18C1.
