Old 03-12-2007, 09:10 AM
timothyn timothyn is offline
S/10 puckup fuel pump will stop runinng
91 S/10
4.3
My fuel pump will NOT stop running. help
Old 03-12-2007, 09:59 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: S/10 puckup fuel pump will stop runinng
Welcome on your first post on AF.
A little more info would help.
What has been done or not done?
Any repair history?
Any add on wiring stuff?
Try tapping or pulling fuel pump relay first and let us know what that does.
MT
Old 03-12-2007, 10:28 AM
Any repair history?
The fuel pump is new from last year but thats it.Nothing esle as been done.
385,000 km and still going. Where is the relay?
Old 03-12-2007, 11:11 AM
MT-2500's Avatar
AF - Advisor
What engine code and S-10 pickup right?
Left front by brake booster.
Also check for power on ECM-B fuse with key off.
The oil pressure switch or fuel pump relay can power the fuel pump if there is 12 volt power on ECM-B fuse.
Pull fuse and relay and if fuel pump still runs it has a short in wiring someplace supplying power to fuel pump.
MT
Old 03-12-2007, 01:49 PM
OK I just moved all the wires around the relay and it worked!
thats alot of wires to look at. So I guess its one of the wires.
Thanks for your help.
