Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-12-2007, 02:44 AM
fastasshell fastasshell is offline
having erk & gerk problems with my 95 2.5 contour
i just got this car a week ago.its a 1995 2.5 5speed contour. and now the car is starting to do this bucking or jerking jolt thing while driving.now i seen in the other post that someone had the same problem. and they said that it had something to do with the (fule pump). when i drove the car for the 1st time it did not do this jurking at all. and the only thing i did was drove it home and parked it. the next day i went to take it for a spin and it started the jurking. now when i 1st drove the car it had about a little over the 1/2 mark on the gas gage. but on that day when it started doing that jurking crap it had only 1/4 tank of gas.today i went to see if anything under the hood looked out of place.but then i said to myself lets pull one of the spark plugs to see what one look like. and the electrode look like it was all most gone. it was smaller than a tooth pic. so i pulled the rest of the plugs out of the front of the engine to look at them as well. and they look to be all most gone too...Okay big (?) and i dont mean to sound like a n idiot. but dose autolite make plug electrodes that skinny. i mean its about this skinny( | )well maybe just a hair bigger.so can this be one of my problems that could lead up to the car jurking. anyway please if anyone has anything im all ears. and thanks for taking the time to read my post.
Old 03-12-2007, 10:39 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: having erk & gerk problems with my 95 2.5 contour
Did they look like this?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 03-12-2007, 11:12 PM
yes they look just like that. so i guess thats what a plat plug looks like. i had know idea that the electrodes were that small. anyway i just learned that today when i went to auto zone to get new ones. anyway please keep me posted if you come up with anything on that jurking problem my car is having and thanks for your time and effort.
Old 03-13-2007, 10:40 PM
now i have a new problem. now the car wont start. well i took it upon myself to take off the air intake mani to look at the wires that go to and from the fuel rails to the fuel injecters. because the wires look to be weather check or brittal. i took the fuel rails off to pull out the whole wireing harness. then i patched the wires up with electrical tape. now i put every thing back together in the same way it all came off. but now it sound like the car has no fuel. it turns over. but it wont start now. now when i turn the key to on. i can hear the fuel pump humming. as if it is working. but when i go to turn it over the humming from the fuel pump stops.is that normal. now could there be something wrong with the fuel rails that go to the fuel injecters.like maybe i have a wire loose or something. because the car started fine before i did this job to it.anyway please if anyone has any idea as to what i did to this car give me a yell!!!
Old 03-13-2007, 11:19 PM
Read here about cracked insulation wires.
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=24
Check the shraeder valve on the fuel rail to see if you have fuel pressure.
"The CEG Nazi"
www.contour.org
Old 03-14-2007, 10:38 PM
ok i will try this. but what dose it look like. is it rounded and black with a cap on the top of it. and when you take the cap off it has a nipple in the middle of it. is this it.
Old 03-15-2007, 08:20 AM
yes thats it.
"The CEG Nazi"
www.contour.org
Old 03-15-2007, 05:30 PM
okay i have gas coming out of that valve. now what. the only other thing i can think of is that the spark plugs. i took one of them and cleaned it with sea foam and a thoot brush. could that of been a dumb move. maybe i made that one plug too wet that when i went to turn the car over as many times as i did that it just flooded its self. anyway if you think of anything just give me yell.and thanks for the info. Do you or do you know any one or where i can get my hands on a 1995 2.5 v6 contour 5 speed fuel injector wireing harness.because i really think a new one would solve alot of my problems. the one that came in the car that i patched up is really.well in other words ...........F%#ked up.
Old 03-15-2007, 05:46 PM
Alright, Im saying it probably has something to do with the spark then. Either its firing at the wrong time or its not firing at all. What you could do is pull out one spark plug and leave the wire attached and crank the car. Just make sure your not holding onto it. You should be able to see the spark. At least that will be able to tell if your getting a spark or not.
As for the wiring harness, id check the ACTUAL contour forums over on www.contour.org. We have a classified section over there and people are always parting out cars. Btw, if you have any more new questions, you may want to take them over there since theres about 1000x more Contour/Mystique gurus than this site. The only people that really respond to questions here are myself, jason, and prezetec98 and were all members of CEG. I honestly just come over here to help you guys and get you to join the real contour forum.
"The CEG Nazi"
www.contour.org
Old 03-15-2007, 07:20 PM
alright thanks man.
Old 03-17-2007, 12:34 AM
okay i went today and got some spark plugs for it.and still nothing. then i tried the spark test with the one spark plugs out and it seems to not have a spark. so if that should be the case then that only means that theirs no fire. so what should i look for next. i turned the key to on to see if the wires that go to the spark plug wire module/ cap what ever they call it. to see if the wires had any power. and the one little wire that goes to the condensor or the little round silver thing thats mounted on the side of the module.and it has power going to it. then i checked the main plug that goes to the module and it only had one wire that had any power coming from it.man i dont know what to look for now. any ideas....and for the spark plugs i just got the cheap ones just to see if the car would fire. before i paid the money for the platenem ones. was this a bad call. the only thing i wonderd is that the OME spark plugs dont have to be gaped. so i did not know how much to gap the non platenem plugs. so i just put them in from the box.no gapping on them.what is the gapping specs on a 2.5 v6 contour.
Old 03-17-2007, 02:40 PM
i called ford and i told them about the problem i had with the wireing harness the one that spiders across the top of the engine from the fuel injector. and i told them that i think that the 1995 2.5 v6 has a recall on the wireing harness. so i gave him the vin # and he had to look it up. and he said that its possible that it has a recall on it. so i may have that wireing probem fix if i can get the car to the ford dealership garage.anyway i will keep posting to let you know how it came out.
Old 03-20-2007, 05:06 PM
well it did not turn out to good. the cars warenty is out dated. and the stupid wireing harness price is out of control. $7.56 seven hundred $ what the f#@K. thats just crazy for someone to have to pay that price for something like that. and if the car had good wireing in the first place no one whould have to replace it. i think that someone should sue the shit out of ford for something like this. now my car is pretty much junk. fu#k!!!
Old 03-20-2007, 08:15 PM
The wiring harness recall is good for 10 year/100K miles. Lukily I got mine in last year before it expired. Cost for the 4 new harnesses is right around $1400. Dont sue ford. Sue the person that owned it before you for not taking it in for a free recall.
"The CEG Nazi"
www.contour.org
Old 03-21-2007, 01:16 PM
your right. im just letting some anger out. so do you have any idea to how someone can get a main harness. other than the dealership.
