Old 03-11-2007, 10:09 PM
jjubeck619 jjubeck619 is offline
ABS Light
99 gt 100,000 miles
I was driving along and it felt like my brakes went out for a split second and then went back to normal, but now my abs light and tracion control light are on constantly. I tried to read it with a scanner but it won't come up and therefore can't be cleared. Any help is always appreciated....thank you
Old 03-11-2007, 10:24 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: ABS Light
It's sounds like clearing the light won't fix your problem, but being able to read the codes could point you in the right direction. Your going to have to find a scanner capable of pulling GM ABS codes.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 03-12-2007, 06:36 PM
Re: ABS Light
sounds like spending time and money at the dealer........no fun!!!!!! Not to mention I have niether.
has anyone else came across this problem??
Old 03-12-2007, 07:18 PM
wethepplebmxer wethepplebmxer is offline
Re: ABS Light
if both lights are on at once, it may be a hub a problem.
The GTP's Kill list:
- 07 Impala SS
- 06 Cobalt SS S/C
- 00 Mustang GT
- 06 Charger R/T
- 90ish Prelude (modded)
- Eclipse GTS
- 03 or so Civic Si
- 96 Eclipse GS-T (some mods)
- 04 WRX (manuel)
- 94 Prelude V-tec (head, cat, more...)
- 06 WRX
- 96 T/A
- 05 300C
Mods: Thrasher CAI, 3.4 pulley, straight pipe (res and u-bend delete), ZZP PCM, Colder plugs, new wires, 180 t-stat.
Old 03-12-2007, 08:34 PM
Re: ABS Light
any further elaberation would be appreciated.....thank you for your help
Old 03-12-2007, 08:42 PM
Bassasasin Bassasasin is offline
Re: ABS Light
Check your ABS fuses and connectors and brake fluid.
Here is where I sucessfully repaired my GM hub ABS light on problem.
Often a bad hub can be diagnosed by Ohming the wheel sensor connections and see if the wheel hub is 1K Ohms... but preferably at the
ABS control module.
If its not somewhat close to 1K ohms track it to the significant wheel and wiring, check at its connector then, replace the hub.. $120...
Elsewise Fuses, and then a diagnostic $80 from a brake shop..
Simple store bought code readers dont read codes from a ABS system.
Good Luck
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
