Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-11-2007, 07:51 PM
clhuff clhuff is offline
jerking
alrite when i shift into second and soon as i let out the clutch the car will jerk and also when im in anywhere from 2nd to 5th gear and really get on the gas the car will jerk alot before it really takes off what is causing this problem...
Old 03-11-2007, 11:20 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: jerking
Sounds like something with ignition or fuel control. First, check and/or replace the spark plugs. Make sure your wires are good with no arching. Next, test the ignition coil.
Problem still happens, then replace fuel filter and then lastly fuel pump.
However, it may be a transmission problem. Jerking like how? When I shift and I let out the clutch too quickly the clutch grabs a hold and jerks the car. That's actually common. Could you explain more?
Also for future purposes, but the make, model, year, and any mods of your car in your signature. It will help us to better help you and know what we're working with. Welcome to AF!
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-12-2007, 10:55 AM
Re: jerking
i dont know its hard to explain kinda alrite just say that im in 3rd gear and i'll be moving along normal rpms no problems.... then if i give it good amount of gas the whole car will start to jerk before it takes off... could it be the clutch
Old 03-12-2007, 11:05 AM
david-b's Avatar
Dave is THAT guy
Re: jerking
If it was the clutch, it'd be slipping. Basically if you were driving normal and floored it say in 3rd gear, the rpms would rise up, but the car wouldn't go anywhere. Thats the worst case when it comes to slipping. However, it doesn't seem like that.
Like I said before, it sounds like ignition or fuel. You're giving it gas and wanting it to move, but it's hesitating and not moving. Either not enough spark for the amount of air coming in, or not enough fuel for the amount of air and spark.
75 Monte Carlo
Old 03-12-2007, 05:08 PM
Re: jerking
the rpms do go up when it jerks
Old 03-13-2007, 07:07 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: jerking
The best way to see if the clutch is slipping is by giving the clutch a huge load. Something like getting part way up a hill at 15mph, putting the car in 2nd and flooring the gas.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 03-13-2007, 04:53 PM
Re: jerking
and if it jerks or whatever then it would be the clutch causing it??
95 talon tsi awd
99 oldsmobile intrigue (dd)
Old 03-13-2007, 05:39 PM
Re: jerking
By placing a huge load on the clutch, it's easier to tell if it's slipping.
I was just trying to give you an easy way to check if the clutch is slipping, but as david-b said, it really doesn't sound like that is your problem.
Have you checked anything that david-b suggested? What about a leak check? How old are your plugs and wires? What are your plugs gapped to? Do you have a logger? Any CEL's? Recent mods?
1997 Spyder GS-T
5-Speed
Old 04-05-2007, 01:21 PM
Re: jerking
alrite its been awhile but lets see all that jerking bs quit when i put my exhasut on dont know why but then all it did was just cut out so alrite changed my plugs to bosh +4 which helped but still does it just not as bad so is it the coil
95 talon tsi awd
Old 04-05-2007, 02:51 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: jerking
That was probably one of the worst things you could have put in...
Take them out and put in some NGK BPR7ES plugs.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
