Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-11-2007, 07:17 PM
airFS airFS is offline
Question electrical or mechanical gauge
I'm looking into buying some aftermarket gauges (boost, egt.) since I'll be installing a new turbo soon. My question is what's the difference between manual and electric gauges. Is one more accurate than the other, is one easier to install, etc. I'd like to get all the info I can.
96' Talon tsi AWD
Mods: greddy upper and lower intercooler pipes _ greddy type rs bov _ K&N intake _ 3" turbo back exhaust _ ngk spark plugs & wires _ garrett T-28 turbo _ greddy oil catch tank
Old 03-11-2007, 07:27 PM
StreetLaw's Avatar
StreetLaw StreetLaw is offline
Send a message via AIM to StreetLaw
Re: electrical or mechanical gauge
the autometer manual advertises accuaracy within 1psi.. how much more accurate can you get for the money..the electrical guage is not necessary in my opinion..
1992 Eagle Talon TSi AWD
Old 03-11-2007, 08:02 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
It really depends on what gauges you are using. I would just go with a mechanical boost/vac gauge, but if you are going to be using oil pres or fuel press. I would recommend electric. You dont want liquids like that running into your car.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-11-2007, 08:36 PM
Are any easier to install??
96' Talon tsi AWD
Old 03-11-2007, 08:50 PM
Holset powered 420a
I think they are about the same. I mean with both you have to tape into the line and then either run wires or a small tube into the car. Just a little more wiring with electric gauges.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 03-11-2007, 11:25 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Mechanic for boost guage. This one you usually want as accurate as possible. Those just require a simple line going somewhere from a vac line to the inside to the gauge.
The rest are easier to have electrical. All there will be are sending units. These, as stated above, tap into exsisitng lines, such as the oil pressure or water temp. Then a single wire runs inside the car to the gauge.
Then, you just need to run 12v power to the gauges for lights and what not. This you can tap from the cig lighter or any other place. Pretty simple though.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-11-2007, 11:27 PM
Holset powered 420a
My oil pressure sending unit has 2 wires going to it.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 03-11-2007, 11:33 PM
david-b's Avatar
Dave is THAT guy
One should goto the gauge... the other should just be a ground, which you can usually mount anywhere, including the block if you needed to. No biggy.
75 Monte Carlo
