Old 03-11-2007, 07:02 PM
Browning151's Avatar
Browning151 Browning151 is offline
SeaFoam advice
I have a 2002 2500HD with the 6.0L. I picked up some sea foam from the parts store today looking to try to quiet the engine down a little by getting rid of some carbon build-up. Can anyone help me out with where the main vacuum line is on this motor and any other tips when doing it? Thanks in advance for any help guys.
Old 03-11-2007, 08:59 PM
thadrawr's Avatar
thadrawr thadrawr is offline
Send a message via AIM to thadrawr
Re: SeaFoam advice
pour half a can into the gas tank and you should be good to go
1999 GMC Sierra 1500
Old 03-12-2007, 02:58 PM
wrparks wrparks is offline
Re: SeaFoam advice
Never tried it myself, but I've heard of people sucking it up through the PCV valve line. Typically, they suck up and let burn about half of it by pulling the hose in and out of the can (don't let it stall). Then, suck it up until it stalls. Let it sit 1/2 hour, then crank it up. No idea if this is a good idea, but I know lots of people that do it. And it will smoke like crazy.
Old 03-12-2007, 10:48 PM
thadrawr's Avatar
Re: SeaFoam advice
ive used it before it makes a ton of white smoke from the exhaust i even scared some kids who were outside playing cause i had to keep revving my engine to keep it from stalling and more smoke kept comming out
Old 03-13-2007, 12:04 AM
Re: SeaFoam advice
So the vacuum line to the pcv valve is the one that i need to use to suck it into all cylinders? I read somewhere on another forum about using the vacuum to the brake booster, but this is the weirdest brake system i've ever seen, it connects to the power steering pump. So i guess i will try the pcv valve line. Hopefully all goes well....will post back with some results tomorrow
Old 03-13-2007, 01:56 AM
Rivx Rivx is offline
Re: SeaFoam advice
I've used it a couple of times. Poured it slowly down the throttlebody. Never got any smoke though like every says it does. Guess there wasnt much carbon built up. These were both 140+k engines.
Old 03-14-2007, 01:14 AM
wyatt_earb wyatt_earb is offline
Send a message via MSN to wyatt_earb
Re: SeaFoam advice
For carbon build up I've always had good luck with tranny fluid. I just run a quart through the brake booster vacuum line, smokes like the dickens though. Also have heard of using water, running it through a cold engine though....
Old 03-14-2007, 05:50 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: SeaFoam advice
The main vac line goes to the brake booster.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 03-14-2007, 06:33 PM
Re: SeaFoam advice
I tried to find the main vac line on this truck, but it doesnt have the big round booster on the firewall like other brake systems I have seen, theres 2 or 3 hoses that go to the power steering pump. Never seen anything like that, it has 4 whl disc brakes also. I have since ran 1 can through the tank and after about 100 miles or so it seems to be a little better but I will still like to find the main vac line for the 6.0 and make sure im using the right one
Old 03-14-2007, 07:36 PM
2000CAYukon 2000CAYukon is offline
Re: SeaFoam advice
You have the hydroboost setup where they use fluid pressure from the ps pump instead of engine vacuum. In your case, the PCV valve will be the largest vacuum hose to use.
//2000CAYukon
Old 03-14-2007, 10:01 PM
Re: SeaFoam advice
Thanks for the tip yukon, I thought that was the weirdest brake setup I had seen. PCV valve it is then!
