Old 03-11-2007, 03:28 PM
HondaManDan's Avatar
HondaManDan HondaManDan is offline
Send a message via AIM to HondaManDan
Exclamation Park Ave Power Steering LOOSE
1995 Park Ave Base...
I recently put an after-market power steering cooler in-place of the stock one because of a leak.
When I installed it I took the cap off the pump, poured fresh ps-fluid in and ran the steering full-swings left and right witht he car running and the cap off... The level didn't go down, so I figured it was full.
Now, having run the car a couple thousand miles, the steering is WAY more loose than it was originally...
Every time there's a bump or a groove in the road it feels like the tires are turning seperate from the wheel... Or, when I wiggle the wheel back and fourth over 30mph there seems to be a delay in the wheel's response, OR it feels like they're OVER turning for the amount of steer I'm applying.
Is there a bleeder on the PS-rack that I missed?? Please help! I'm extremely scared to be driving aroun like this.. (plus I don't know how much damage I'm causing, if any.)
Also, could this be a tie-rod end problem? not PS?
Dan
95' Buick Park Ave... hell yeah.
Old 03-11-2007, 07:41 PM
Greg5150 Greg5150 is offline
Re: Park Ave Power Steering LOOSE
See if your inner tie rods have any play. I had to replace one on my 1992 Park Ave because the steering was lose.
Old 03-11-2007, 09:24 PM
Bassasasin Bassasasin is offline
I agree to look for looseness.. or toe out..
Good Luck
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
Old 03-12-2007, 01:15 AM
Yea, I just came home and there's definately toe-out on my passanger side. I can be going in a straight line, holding the wheel straight, and all of the sudden the car will drift to the right out of no-where... not violently.. but NOTICIBLY.
I'll put her on the jack tomorrow.
Dan
Old 04-01-2007, 10:29 PM
Well that's the last time I use the air-pump at a certain gas-station. I had put 37lbs of air in my tires... as I always do...
Turns out when I went into MY shop to check my tires out the pressure read 62lbs!!!!!!!!!!!!!!!
THAT is why the car was swerving so badly. Everything was tight as far as tie-rods and ball-joints... it was the goddamn tire pressure.
I have let that particular gas-station know and they replaced the air-gauge end that day...
I can't believe it was 30lbs over. I'm surprised I didn't die.
Dan
Old 04-02-2007, 10:59 AM
kmax1 kmax1 is offline
Dan
That's crazy, glad the tire didn't explode when you were filling it up. I always carry around a digital gauge in the glove box.
I'm amazed it didn't let loose when you filled it to that. Your miles per gallon probably shot up though!
