Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-11-2007, 01:08 PM
CD Smalley CD Smalley is offline
Headlight swap - sealed beams to composite on 86?
One of my Caprices must go away. Looks like it will be the 89 since the body is in such rough shape now.
Anyway I want to swap the composit headlight into the 86. I seem to recall someone have done this without swapping the header panel. I spent about an hour looking at the two side by side yesterday and I don't see it being possible. Not without swapping the header panel at least.
Anyone have any further into on this? Anyone done this?
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 03-11-2007, 02:32 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Headlight swap - sealed beams to composite on 86?
You cannot easily do it without swapping the header panel - the headlights on the '86 have a more shallow mount point, where the '87-'90 is much deeper. If you're getting rid of the '89, why not keep the header panel and use it on the '86?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 03-11-2007, 04:36 PM
I think i will have to do that. White on gold will look crappy. Guess there is some painting in my future.
I thought someone claimed to have done this swap without issues though. I don't see it happening very easily with my two though.
I guess it's time to start wrenching!
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 03-29-2007, 03:34 AM
ncinirator's Avatar
ncinirator ncinirator is offline
Send a message via AIM to ncinirator
Anyone remember when you could buy the GM headlights that were blacked out until you turned on the headlights?
Those looked cool, I don't think you can get them anywhere now.
94 Caprice 9C1, 84 CUCV Blazer, 07 TL, 96 F250 PSD.
Old 03-31-2007, 11:35 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Use window tint on em.
Old 04-11-2007, 09:22 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
the panels changed you need the 87-up panel assembly, entire thing,
also the harness,
when i did it on one of the 83 caprices that i had i hacked the harness on the inner fender under the hood there by the hood hinge assembly and butt connected the wires there instead of unbolting it from the main body connector at the firewall
worked fine
i have pics somewhere of the entire swap, its real easy/simple to do,
heres after i did it to my 83:
i n4ever did get to totally finish it up and paint it, it ended up getting impounded in chicago,,, :-( was a low miles all original nice driving one too :-/
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 04-12-2007, 05:19 AM
Hmm. Sounds like it's time to start taking the parts off the 89 now....
Thanks All!
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 05-06-2011, 10:47 PM
Dacaprice Dacaprice is offline
I would like some more info on this as I want this done to my 86. what needs to be done to do this without swapping panels?
