Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-11-2007, 04:10 AM
hahapopcorn hahapopcorn is offline
Question plugs + wires?
Hi. I was wondering if it is recommended to change the plug wires and the plugs at the same time or does it matter which one i switch out first? and also how often do you have to change them? thanks
The new plugs I have now but the wires aren't coming in untill monday =/
Old 03-11-2007, 05:45 AM
XeVeNskyLiNE's Avatar
XeVeNskyLiNE XeVeNskyLiNE is offline
Turbo makes me emo!
Send a message via AIM to XeVeNskyLiNE
Re: plugs + wires?
The only reason you'd really need to change the wires is if you're upgrading, they're damaged, or they're just really really old. And its perfectly fine to go ahead and put your new plugs in while you wait for the new wires.
As for how long to change your plugs, I'm not really sure, I always changed mine when I "felt" like it was time. I think I remember people saying placing them every oil change would be suffecient.
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv
Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM
Old 03-11-2007, 01:03 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: plugs + wires?
I agree. As for change interval, if your DSM is turbo then probably every other oil change is fine. If your N/A, you could probably go 10,000 miles inbetween plug changes. Just make sure you gap them properly. Wires you probably will never need to replace again.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 03-11-2007, 03:47 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: plugs + wires?
I replace mine every time I change the oil. Just make sure you gap them properly and only use NGK, non-platinum plugs.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 03-11-2007, 11:11 PM
Re: plugs + wires?
Darn, I just bought the NGK g-power platinum plugs. whats wrong with the platinum ones? o.O
Old 03-11-2007, 11:38 PM
Fierc3 Kid's Avatar
Fierc3 Kid Fierc3 Kid is offline
Send a message via AIM to Fierc3 Kid Send a message via MSN to Fierc3 Kid Send a message via Yahoo to Fierc3 Kid
Re: plugs + wires?
I think its something about the electrode breaking under boost, and that platinum isn't as good of a conductor as copper is. Correct me if I am wrong.
91 Eclipse 1.8 10X
Old 03-12-2007, 01:32 AM
Re: plugs + wires?
I love how everyone assumes you are turbo. Which is it? If your N/A, platinums are ok but not recommended.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 03-12-2007, 02:39 AM
Re: plugs + wires?
yes a 95 awd tsi, large 16g turbo, 92 head/tranny. So if i use the NGK g-power platinum spark plugs will something go wrong with the car? or will the performance just be crap? thanks to everyone who has helped me
Old 03-12-2007, 07:15 AM
Re: plugs + wires?
The platinum retains heat longer than the copper style plugs which keeps them from fouling as quickly. It's also not as good of a conductor as copper. The added heat leads to a "hot spot" within the cylinder. This can cause a lot of problems, including knock under boost, hesitation, poor idle, lost power, etc.
You can pick up NGK's for about $1.50/each, so I would definately ditch the Platinum in favor for some copper NGK's.
1997 Spyder GS-T
5-Speed
Old 03-12-2007, 11:31 PM
Re: plugs + wires?
Thanks to everyone whos given me advice. Update: When i had the platinum plugs in the car bogged like CRAZY when i tried to boost, i switched it back to copper ones and now its fine. the funny thing is when i put the copper ones back in the rpm idle is a bit weird (normal idle 500-550 but jumps to 1.5-2k every now and then) didn't seem to do that with the platinum ones o.O
I'm waiting for my new plug wires to come in, ive been runnin stock plug wires yet the car is a bit upgraded (could cause some problems?) it has a large 16g turbo and some other things.
Old 03-19-2007, 12:42 PM
violent31601's Avatar
violent31601 violent31601 is offline
Send a message via AIM to violent31601
Re: plugs + wires?
I always buy the really expensive Irridium ones
Old 03-23-2007, 11:01 PM
Turbo makes me emo!
Re: plugs + wires?
I wish Autozone would sell NGK's, I've used Denso Iridiums for the longest and they seem to work really good.
