Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 03-10-2007, 09:09 PM
super.cee super.cee is offline
83 El Camino loose steering wheel
Need help with access to 4 torx bolts (E8) to tighten loose steering wheel.
have removed, steering wheel, lockplate, directional signal, and tilt steering pins, but the assembly is still blocking access to 2 of the 4 bolts. Help please.
Old 03-11-2007, 06:26 AM
frogman6042 frogman6042 is offline
Re: 83 El Camino loose steering wheel
after removing pens the upper housing should come off and put you right at the screws make sure you use lots of lock tight on them or you will right back at it again!
Old 03-11-2007, 03:11 PM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
Make sure you have removed the tilt housing spring before you remove those 2 side pins. After those are removed, pull the tilt lever (like you were going to change tilt positions) and then you can release the tilt housing from the base and have full access to all the bolts. Email me if you need further instructions or pictures.
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
