Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 03-10-2007, 07:04 PM
topix topix is offline
05 Dakota Stalls
The transmission in my 05 Dakota 4X4 when cold will stall the engine when coming to a stop. Trans kicks down to lower gear with a small lunge forward if brake is not applied hard. If brakes are set hard it will stall the engine. Seems like it does not want to disengage. Dealer has had it a couple of times to no avail. No codes, and says cannot duplicate. Only occurs within the first 4-5 minutes of cold driving. Any ideas or others experiencing the same problem.
Old 03-10-2007, 09:38 PM
xj31 xj31 is offline
Re: 05 Dakota Stalls
Does it have a 4.7?If the answer is yes,the trans fluid is probably about 1/2 quart low.I am a tech at a dealer and we see this a lot.
