2004 passenger water leak!!!
Has any one experienced a passenger side water leak in a 2004 or newer? My car leaked when the snow flurries melted on the window throughout the day. Is this the same kind of leak that is described on the previous model GP? I'm going to check it in the morning. Any insight would be grealty appreciated.
mark ![]() Love my Pontiacs! '04 GP GT1 '02 Bonneville '98 GTP - 2 dr '98 GTP - 4 dr '99 GP "Flaming Tomato" GT |
Re: 2004 passenger water leak!!!
I would guess that it's likely the same problem.
Do any of you have a sunroof/moonroof combo?
When I got my GTP the dude said if I get water on the passenger inside, (this is not to be confused with water on the passenger floor, like an evap/heater core leak) that I will need to clean out the channel in the sunroof/moonroof. Now I havent had the issue yet and havent even seen it, but check it out.
Go with the flow and make it fast... ![]() ![]() 2001 GTP- few mods, very fast? hoping
Great question! In my case, I do not have the moon/sun roof option installed on my GT.
I dont have a moon roof/sun roof either and it was also all the way in the back on the passenger side. The oem warranty is over and the Pontiac service guy said $175 just to start looking for the problem. It's a GT2 with everything except the monsoon, nav and moon roof.
very common problem in the '04s, the cabin filter needs to be changed and you need to clean the leaves out of the duct above it... the '05s and up got a rubber flap installed on them which prevent this from happening, this happened to me right after I got my gtp...
autozone.com has one for $11.99 its part # P3720 and its made by Bosch, easy to change... http://home.comcast.net/%7Ewarren.family/Cabin.html hope that helps
2004 Pontiac Grand Prix GTP Custom K&N Fenderwell Intake , 180° thermostat, 3" Down Pipe, High Flow Cat, DHP 1.0 PCM, 3.5" pulley, 1.9 Ratio Roller Rockers, 90# LS6 Valve Springs, AL104s, ZZP Motor Mounts, 17" American Eagle 192s, Magnaflow tips. ![]() not just babies whine |
I can't believe I found this info...isn't the internet great. Now, to clarify for a non-car person.
My car leaks when it rains. The front passenger floor is wet and sometimes the floor behind the passenger seat is wet. To fix it, all I need to do is replace the cabin filter? Isn't this a part that the quick lube places always try to upsell you on? Or is that something else? Thanks for this info, my car is soaked this morning!!! |
YES!
they will rip you off, the part they want $40 for, you can get at autozone for $11, and its EASY to install... also make sure you clean the duct, its probably full of debris...
