Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 03-10-2007, 05:00 PM
vetteguy96 vetteguy96 is offline
EGR valve on 96 Sunfire
I have a code P1406 on my 96 Sunfire w/ 2.4L engine. P1406 = EGR temp sensor range/ performance. EGR valve pintle position circuit. Does this normaly mean the EGR valve needs to be replaced or is there another less costly fix. Thanks in advance, Guy
Old 03-10-2007, 06:27 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: EGR valve on 96 Sunfire
Clean the valve with throttle body cleaner. They get carboned up and that can cause issues. If that doesn't help then it will need replaced. Try car-part.com for a used one.
Old 03-10-2007, 07:16 PM
Thank you very much.
Old 06-22-2007, 02:38 AM
ernesto821 ernesto821 is offline
do that EGR valve effect performance or anything at all? I got that problem on my 99 dodge neon. I finally end up replacing because i can't that check engine light. but, i don't think it affect on driving..
ps: that replacement costed me $250+ about half for the EGR valve and the rest for labor..
Old 06-23-2007, 10:43 AM
ChemMan ChemMan is offline
The EGR valve can effect performance. I know from my old Ford that not having a functioning EGR valve made the car a little more powerful at the low end, but the pinging (pre-ignition) at high speed sapped so much power that the car couldn't maintain speed up a steep hill. Should be the same deal for your car, although the computer controls will probably hide the effects from you. Most importantly, the pre-ignition can and will eventually destroy your engine.
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
Old 07-26-2010, 01:40 PM
jdunbar14 jdunbar14 is offline
i have the same code p1406 for me 96 sunfire but with a 2.2 in it and it chugs on take off and then stops for a bit and then dose it ever so often when crossing one speed would the EGR make that to happen?
