Old 03-10-2007, 03:59 PM
jwokmuba2 jwokmuba2 is offline
Question 4x4 problems/questions
i have a 1988 chevy 2500 4x4 with a 5.7 liter tbi motor, the problem is that the 4 wheel drive is not engaging, i was wondering what it could be, someone told me the actuator would be the problem but before i spend 90 bucks, i what to know what else i could be?
Old 03-10-2007, 05:42 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 4x4 problems/questions
You will have to craw under there and have a look.
Is 4W shifting in good?
Is the front axle locking in?
Old style 2 wire actuator?
Check fuse to it.
Got juice and ground?
Have a look at the wiring plug in to it.
MT
Old 03-23-2007, 10:09 AM
bamadam bamadam is offline
I can almost guarntee that is your problem. AND unless it has changed you will have to buy a different wiring harness to make it work which has one wire that runs ALLLLLL the way to the tailend of the tranny and must be "spliced in".
But it works like a charm when done. That's the good news.
Old 03-24-2007, 06:45 AM
Jeremy-WI Jeremy-WI is offline
He might not be able to use the updated actuator on his truck, the tsb excludes 1988 to 1993 that have a gvw over 8500lbs, and if he has 8 lug wheels the newer style actuator won't work
Old 03-24-2007, 07:57 AM
My apologies. Good luck
