Old 03-10-2007, 03:12 PM
slough23 slough23 is offline
Has anyone tried the following products?
I drive an '04 2500 crewcab with a 6.0 gas engine and a canopy. Loaded with three adults, and the bed packed driving down the freeway I can manage 14+ mpg going 70 mph.
Locally the press is prepping us for gas at $3/gal in the coming months and with regular at $2.70 which is .60 higher than this time last year, 3 bucks a gallon might be cheap.
So I'm looking at ways to coax a little more effiency out of each gallon and was wonder if anyone has any first hand experience with the following products. If so, ease of installation, effiency improvements and since you have used it, is it worth the $$$$ outlay.....
-Eco Fuel Systems
-Fitch Fuel Catalyst
Thanks.
Old 03-10-2007, 04:59 PM
muff34 muff34 is offline
Re: Has anyone tried the following products?
3.00 bucks a gallon , where can I get me some of that...............LOL . It`s only 4.92 a Gallon here NOW. the U.S. gal is smaller than the imperial gal in Canada , and so converting things back to your gallon it is still paying 4.15 a gallon . Some will post that we use the liter here which is correct however doing the conversions these are the stats. LOL
Life Is A Highway ,Enjoy The Ride
Old 03-10-2007, 05:58 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
14 is not real good mileage.
Most of that gas saving stuff is snake oil.
There is no magic bullets for it.
Your best bet is to keep it tuned up good with good clean air and fuel filter..
Little things like tire pressure and good driving habits like slow take off and easy stops play a role in better gas mileage.
Next size bigger tires may help some.
Also try steady cruising at a different speed like try 60 or 65 MPH may help.
Good luck
MT
Old 03-10-2007, 06:49 PM
LilRedBoTie LilRedBoTie is offline
Do you have any aftermarket stuff done to it? If not I put an exhaust system, a K & N FIPK, and a programmer on my last Chevy and picked up around 3-4 mpgs plus the added power. They are well worth the money.
Old 03-10-2007, 06:54 PM
I put an AirAid air filter and intake on, haven't touched the exhaust because of increased noise factor......what exhaust and performance chip did you install?
Old 03-10-2007, 08:54 PM
I just cut stock muffler out and ran a 40 series Flowmaster that dumped right before rear axle. And I used a hypertech programmer on it. It seemed to work pretty well.
Old 03-13-2007, 12:02 AM
guumbah's Avatar
guumbah guumbah is offline
Put on an FIPK and 50-series Flowmaster, at the same time, transferred jobs from 90% freeway commute to 0% freeway (but only 10% of distance ) and with ALL stop and go now, I still get 10% more mileage per tank than before.
2002 5.3l - Quadrasteer
lose (lüz): v - to suffer deprivation of : part with especially in an unforeseen or accidental manner
loose (lüs): adj - not rigidly fastened or securely attached
Old 03-13-2007, 01:48 AM
bigbadram51 bigbadram51 is offline
I gained 1-2 mpg after my Nelson Tune. About a year and a half ago I posted a thread about some of those gas saving gizmo's
http://www.automotiveforums.com/vbul...d.php?t=451520
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 03-13-2007, 01:52 AM
3" PA Body Lift
Covermaster Top
Old 03-14-2007, 01:06 AM
Tdragone Tdragone is offline
What tires are you running? When I went from stock tires to my BFG's I lost almost 2 mpg due to all the rubber. Rotational Inertia is a Bit**. Adding my shell didn't change anything.
Old 03-14-2007, 01:41 AM
At the time I was running 305/50R20 Toyo Open Country AT's. Those were near stock size, just sig. wider. Since I added the lift and 35's my mileage obviously has gone down, havent re-geared yet (4.88's in the next few weeks are going it).
3" PA Body Lift
Covermaster Top
