Old 03-10-2007, 01:17 AM
ab4u ab4u is offline
Exclamation Someone with knowledge please!
Any Professional Help Will Be Greatly Apprecitated I have 2 audiobahns 12" subs with 400rms each. Yes thats 2 audiobahns.. i need to find an amplifier that will power these 2 nice but i dont know what rms wattage amplifier to get... also is MA AUDIO AMPS any good ? because im not looking to buy a really expensive amplifier so let me know if they are any cheap amplifiers out there that are really good quality I dont want to blow up my alternator and upgrade my engine parts so please keep that in mind when suggesting...Please reply asap thanks
The specs for my subs.. please dont crticize on my subs because i already have them thanks
12" High Performance Subwoofer
45 OZ. Strontium Magnet
2" 4 Layer Black Aluminum Voice Coil
400W RMS Power Handling Per Sub
800W RMS Power Handling Per Pair!
24Hz - 1kHz Freq. Response
92.1dB Efficiency
Bumped & Vented Polished T-Yoke
Poly Coated 2 Layer Non Pressed Paper Cone
Lug Lock Terminals
Dual 4Ω Voice Coils Per Sub
1 Ohm or 4 Ohm or 2 Ohm Stereo Operation
Rubber Gasket & Magnet Mesh Cover
5-1/4" Mounting Depth
Old 03-10-2007, 05:35 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Someone with knowledge please!
find a class D amp rated for like 800-1000 watts RMS. then wire the voice coils on the subs in parallel and then the both subs in parallel - that will give you a 1 ohm load.
