Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 03-09-2007, 11:31 PM
lopezbros lopezbros is offline
Need help!!!I cleaned out my throttle body.....
I cleaned out my throttle body with some gumout carb cleaner..after doing that i hooked everything back up..reved the engine..and is now accelarating fast as hell...any clues as to why its doing this?
Old 03-10-2007, 08:39 AM
caddydaddy caddydaddy is offline
Re: Need help!!!I cleaned out my throttle body.....
Check to make sure nothing is binding with the throttle cable. Also, did you disconnect the battery when you cleaned out the throttle body?
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
Old 03-10-2007, 11:51 AM
Re:
no i didnt disconnect the battery...nothing is binding with the throttle cable...
Old 03-10-2007, 11:54 AM
oh and this morning i cranked the engine and the dashboard reads.....service idle control system?
Old 03-10-2007, 02:13 PM
maxwedge maxwedge is offline
A990 racer
You may have damaged the control, is it properly reconnected?
Old 03-10-2007, 02:45 PM
What does the control look like?
Old 03-11-2007, 10:25 AM
A990 racer
ISC connects to the TB, on the side near the throttle opening.
Old 03-11-2007, 12:02 PM
DFBonnett DFBonnett is offline
Double check your work. Did you clean both sides of the throttle plates as well as the bore? Look for a vac line that might have gotten broken or disconnected. Disconnect the battery for a couple of minutes then reconnect. That will reset the comp to default for the idle settings. That should do it. You''ll have to reset the radio selections and it will take a few miles od driving for the fuel range to reset.
Old 03-11-2007, 05:00 PM
ive tried all that already...any more suggestions......
