Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-09-2007, 11:07 PM
wanted1's Avatar
wanted1 wanted1 is offline
Send a message via Yahoo to wanted1
Question 97 eclipse turns over but wont start!
Hi there all i hope im in the right place i just joined up but anyway im thinking about trading my Trans Am for a 97 eclipse rs that has the 420a engine and it is fully customized under the hood and outside but he bought the car on e-bay and when it got to his house he canot get it to start her is the list of mods it has
Fully Built 420a
- Eagle Rods
- Wiseco 8.8:1 Pistons
- Total Seal Rings
- Bored .02 -
- Cometic Head Gasket
- Melling Oil Pump -
- New Water Pump -
- New Timing Belt -
- Crower Valve Springs -
- Crower Retainers -
- Ferra Valves -
- Crower Custom Cams-
- AEM Cam Gears -
- Ported & Polished Head -
- Milled .04
- 5 Angle Valve Job
- AFX Underdrive Pulley -
Venom Intake Manifold (Anodized Red) -
Venom Fuel Rail -
Ford Racing 42# Injectors -
Aeromotive 1:1 FPR -
Aluminum Radiator (300 Miles) -
Apexi N1 Exhaust - (1000 Miles) -
High Flow Cat -
HAHN Port Fueler (NEW) -
Turbo Kit W/Upgraded Parts -
- Star Turbo Manifold
- Tial 38MM Wastegate
- Turbonetics T3/T4 Turbo
- Star Downpipe
- SS Oil Feed Line
- SS Oil Retun Line
- Hahn FMIC
- Hahn FMIC Pipes
- All Silicone Couplers
- Hahn Fuel Mapper
Defi Temp Gauge -
Defi Boost Gauge -
Defi Fuel Pressure Gauge -
Defi EGT Gauge -
Defi Air/Fuel Gauge -
GReddy Profec B Spec II -
GReddy Turbo Timer -
PLX300 Wideband O2 Sensor -
Black 3 Gauge Pillar Pod -
Black Gauge Bezel Pod -
Tanabee Proceedo Down 2" Springs - $250
J-Sport Crossdrilled & Slotted Rotors
allthis stuff is installed and the car turns over and acts like it wants to start but wont just wanted to know if it would be hard to track down the problem because i am seriously thinking about tradeing him any thing will help thanks
Old 03-10-2007, 02:15 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 97 eclipse turns over but wont start!
Has he ever actually had it run since he has built it? If not then I would be very leery of this as there could be some major problem with it...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-10-2007, 07:38 AM
wanted1's Avatar
Question Re: 97 eclipse turns over but wont start!
no he bought it from a guy in flordia off ebay and we live in alaska so he could not see it in person befor he bought it but the guy said it ran fine down there but after it was shipped up here he tried to start it and it turns over but does not start he said a shop said it might need a bigger fuel pump or some kinda program but i dont trust what the shop said cause of there credibility so im seeking assistance the car is in showroom condition in and out but dosent start i just need info on what i can check out on it or things that i can do to get it to run i dont know alot about eclipse's but i know enough about engines to understand what your talking about so any info on oh and it was an 97 rs auto converted to manual tranny thats all i know till i go look at the car and see for my self i got pics but dosent help with sounds and such ..lol
Old 03-10-2007, 01:12 PM
Well, I would run through all the basic things to check first. Make sure its getting fuel into the cylinders, check spark, timing, etc...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-13-2007, 06:01 AM
MazdaX's Avatar
MazdaX MazdaX is offline
Haha...Alaska is a bad spot for an Eclipse, I should know XD
Anywho, one of the bigger problems might not be the ecu con't compensate fuel through fuel mapping but could be something other like no fuel at all, no spark at all, fried brain , no compression, ..a multitude of things or maybe just something simple like vacuum. start with the basics like 'He' says and go from there.
2004 Mazda 6i
1997 Tahoe
Old 03-24-2007, 04:16 AM
wanted1's Avatar
ok it has spark and is definetly getting fuel i havent been able to check the timming though it will start when the car is warm in the garage but is running verry rich and when you give it gas it boggs down and then reves up but is verry unstable it has a stock ecu ,my question is can i put a ecu out of a turbo model eclipse in it ? because im pretty sure the ecu is bad and the car is just getting way to much fuel the exaust is black and sooty . some advice on this would be greatly apreatiated.
Old 03-24-2007, 09:21 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
No you cannot. The 4g63 ECU will NOT match up with it. You list the Hahn fuel mapper. You may have to play with that to get it right.
If you think the ECU is bad, replace it then. But only with a 420a ECU.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-24-2007, 10:38 AM
wanted1's Avatar
ok will look at the fuel maper and tinker a bit with it see if that helps out im just new to the turbo engine and as much mods as this car has just makes it that much more confusing but im reaserching as much as i can so i know every thing i do will be corect also with all that i listed the stock ecu should work fine right ? I mean if all the other stuff is in proper order
Old 03-24-2007, 11:30 AM
Yeah, the ECU swap ain't gonna happen unless its for another 420a... Sounds like the fuel map is just all jacked up and needs fixed... After re-reading this, why would you trade a Trans Am for an Eclipse RS?? Or is the Trans Am like my bird and has seen better days? lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-24-2007, 11:42 AM
Scrapper Scrapper is offline
AF Premium User
i'd check timing you can get it on number 1 by turning it over and see if it's on number 1 piston come up and see if it is on number 1 by harmonic balenser...good luck....
Old 03-24-2007, 02:47 PM
david-b's Avatar
Dave is THAT guy
Dont go messing with the fuel maps unless you know what you're doing. Seems like it may be either way to rich or lean at idle. Just lean it out a little and see what happens. I can't emphasize this enough... A LITTLE!! Small changes in fuel maps.
75 Monte Carlo
