Old 03-09-2007, 10:22 PM
petermcnulty petermcnulty is offline
obd1 conversion
Alright, I know I need:
conversion harness
dizzy
ecu
o2 sensor
But my question is what are my options for ECU's. I drive an 88 CRX DX with the stock d15b2 engine.
Old 03-10-2007, 12:40 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: obd1 conversion
I would stick to OBD0 for that motor. Step up to OBD1 if/when you swap motors to a OBD1 motor.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 03-10-2007, 01:10 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: obd1 conversion
Your obd0 dpfi setup only has 2 injectors. The problem you will run into is that none of the obd1 honda civic ecu's are built to run only 2 injectors. If you do want obd1, you'd have to do a minimum upgrade to the mpfi conversion as well as the upgrade to obd1. Just for curiosity sakes - why are you wanting to upgrade to obd1??
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 03-10-2007, 10:00 AM
Re: obd1 conversion
well the plan was to turbo and to use either crome or s300 for tuning, which won't work with obd0. I did plan on going MPFI anyways but i still wouldn't know which ecu to use. I may just consider a zc swap.
Old 03-10-2007, 03:54 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: obd1 conversion
Wait till you at least do the mpfi or upgrade to another motor before converting to obd-1. You can run an obd-0 turbo setup and get your ecu chipped but obd-1 is as you know more tuner friendly. First ditch the dpfi.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 03-10-2007, 09:35 PM
Re: obd1 conversion
yea i was going to do the MPFI conversion reguardless. is there any other practical ways to tune obd0 besides turbo edit (which as far as i know doesn't exist anymore?) Also i don't think i can chip my ecu.I read something about not being able to chip 88 and 89 pm5's. I just want to get a simple 6-8psi turbo build started asap.
Old 03-11-2007, 02:11 PM
Re: obd1 conversion
Come on man, you can't run a pm5 with a turbo set up. Pm5 is a dpfi ecu and is garbage. If you do an mpfi swap and maybe throw in an A6, get yourself a 90-91 pm6 ecu, those are chipable. 88-89 ecus are not.
Old 03-12-2007, 08:46 PM
Re: obd1 conversion
i was thinking, rather then do a swap, would it be better to swap to MPFI and then get a megasquirt? Eliminate my stock ECU altogether. Anyone else done it? I looked but it doesn't seem to be popular.
Old 03-14-2007, 01:43 AM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
Re: obd1 conversion
you could do that but you would still need the ecu for spark and such. senors and all that but it is prett much worthless to do a obd-1 swap on that motor. i would just do like it was said before. grab an a6 and boost it or maybe a dohc zc.
Old 03-14-2007, 09:05 AM
4G4D Store's Avatar
Re: obd1 conversion
You can run OBD0 and turboedit with a chipped ecu and do the same things as you can with crome without having to convert to obd1 and use a pm6 ecu. That's what I'm doing.
Old 03-14-2007, 09:06 AM
4G4D Store's Avatar
Re: obd1 conversion
Old 03-14-2007, 04:15 PM
Re: obd1 conversion
can I use a pm6 with my dx (d15) engine after converting to MPFI?
i found the turboedit download, im gonna put around with how it works and such
Old 03-14-2007, 05:28 PM
2poor2tune's Avatar
Re: obd1 conversion
yes after converting to mpfi you will need the pm6 to run your motor. but you should get a 90-91 so you can chip it. pretty simple. oh and the pm6 is the stock si ecu if you dident kow. fyi
Old 03-14-2007, 07:57 PM
Re: obd1 conversion
Ive been reading up on turboedit for a couple hours now. i think im gonna buy a pm6 chipped from xenocron. Can i run it chipped before I tune with turboedit? I just figure if they can chip it for me for only like 20$ more, why not just take care of it now. Or if not I would assume I could just burn a chip for running stock (unless im not understanding this right). Until I piece together the rest of my turbo kit.
also, anyone know of any reasonably priced quality chip burners?
Old 03-14-2007, 09:09 PM
4G4D Store's Avatar
Re: obd1 conversion
If you want to bypass the chip burner, get the moates ostrich - it's a obd0/obd1 chip emulator. It's real time programmable instead of reburning chips all the time. I just bought mine for $175 - can't wait to get it in and play with it.
