Old 03-09-2007, 08:07 PM
ziggy61 ziggy61 is offline
02 Grand am Trans problem?
I have recently purchased a 2002 Grand am SE1. Overall it's in good shape. I have just a couple of annoying problems. (1) there is a "squeal" when I make a hard right turn and (2) there is a "chugging" at 40-55 mph. The second problems concerns me more. I can let off the gas, then accelerate, and the car the problems smooths out. The engine performs fine otherwise. I have noticed that I don't have the problem if I drop into 3 rather than D. I have already replaced the spark plugs and wires, and one mechanic thought it might be the fuel filter, so we replaced that too. I've heard "overdrive sensor" and other transmission possiblities. Your suggestions please?
Old 03-09-2007, 09:29 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 02 Grand am Trans problem?
Welcome to AF.
The sqeal is probly the belt or your power steering pump.
This can happen if you turn the wheel to hard in either direction.
With the chug I'd try changing your trans fluid & filter.
Though I would not have it flushed
Could try some seafoam trans treatment before you change the fluid to see if that clears it up.
1999 Grand Am SS 3.4 OHV
Old 03-15-2007, 05:36 PM
I've taken the car in to a trans shop, and diagnosis there revealed no engine or trans codes in the computer. Of course, it runs fine when the mechanic drives it. Last night the chugging worsened. With AC on, it starting chugging then bucking. I tried to push it, by accelerating, and it just bucked and jumped,like it wasn't getting gas. Could this be in the fuel system?
Old 03-15-2007, 06:44 PM
dragos69ca dragos69ca is offline
Originally Posted by xeroinfinity
Welcome to AF.
The power steering pump doesn't make a difference between left and right turn...if you have the noise on both direction then the pump is noisy...regarding the treatment I don't suggest that as these "performance fluids" have a different viscozity than the original designed...I had problems with these treatments.
SS-Steering
Old 03-16-2007, 06:51 AM
Chuging..... I Still would try that Seafoam Trans treatment
And or get the trans fluid & filter changed.
As most "chuging" I have seen, is from varnish biuld up in the valve body causing shift solenoids to stick causing the chug.
btw how many miles are on this GA??
And on the noisey PS Pump,
it is recomended that the fluid(& filter)be changed every 30-40k miles.
Just changing the fluid can help with noise.
Both of my GA's are running Synthetic ps fluid.
They both used to have bad psp noise, they've been fine since the change to synthetic .
This can be true dragos69ca.
Some products are bad for your trans, though I have never heard or seen any problems with seafoam products.
Viscosity realy isnt anything to worry about with treatments.
Its more about the crap put into the products that can swell, & or dry out rubbber seals inside the trans.
Or they contain harsh chemicals that can damage clutch(bbands) face materials.
