Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-09-2007, 08:37 PM
ryno2324 ryno2324 is offline
71' Old 455 fit into 79' Trans Am?
Anyone ever put a Buick 455 in a trans am? Don't know if the shaker hood will close of if the shaker will fit on the carb. Just bought a '79 TA and the 455 is mounted without the manifold or carb. Want to know if I rebuild the 455, will the hood close over the shaker for a perfect fit just like the Pontiac 455.
Old 03-10-2007, 06:22 AM
Morley Morley is offline
Re: 71' Old 455 fit into 79' Trans Am?
The Olds 455 is a big block and all Pontiacs have the same dimensions as a big block. So it should fit. You'd just need to watch which manifold you use on the Olds, no high rise manifolds.
Old 03-10-2007, 01:44 PM
Thanks Morley. It appears that the carb location is about 2" too far back as well. Is there a manifold that will locate the carb closer forward?
Old 03-10-2007, 04:08 PM
That I don't know. Try calling Summit Racing's tech line and see if they have something. If they don't have one or know, contact these guys http://www.mondellotwister.com/
