Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 03-09-2007, 06:34 PM
manny18 manny18 is offline
Question on wirng aftermarket sub amp in LS
Newbie question here, I have a 2001 Lincoln LS with Alpine 6 CD in dash with factory preamp Subs in the deck. I just bought an aftermarket 1600W Sub amp with JL audio pair of Subs. How do I wire the amp input(s) in place or in conjunction with the factory Sub preamp and woofers?
Old 03-09-2007, 09:06 PM
Quik_LS's Avatar
Quik_LS Quik_LS is offline
Send a message via MSN to Quik_LS
Re: Question on wirng aftermarket sub amp in LS
The trunk connector (on the drivers side) is number C465 and the sub audio uses these pins:
1 = yellow/red: switched hot
3 = shield for low level audio signal
5 = red: constant power from battery junction box fuse F418 (20 amps)
7 = white/red: low level LEFT audio signal
8 = grey/red: low level RIGHT audio signal
Quik LS - Austin, TX
more, more, more.....
#0018 ESP SCCA solo2
LLSOC.com - President
see my mean LS
see my Lotus Esprit - Quiker
Old 03-10-2007, 09:13 AM
Thanks a lot Quick LS, do I disconnect and remove the preamp and factory subs completely?
Old 03-10-2007, 02:17 PM
Quik_LS's Avatar
right - the LS uses a seperate sub-woofer amp - 85W - that drives the two rears.
see my mean LS
