Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 03-09-2007, 01:03 PM
machete619 machete619 is offline
Send a message via AIM to machete619 Send a message via Yahoo to machete619
water pump
how can you tell if the water pump is going bad beacause i hear nosie coming from it
Old 03-09-2007, 01:17 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: water pump
If it's noisy, the bearings are probably going out in it. How many miles on it?
2003 Dodge SRT-4
Old 03-12-2007, 12:49 PM
Re: water pump
theres about 97,000
Old 03-12-2007, 12:53 PM
Re: water pump
You are nearing the 100,000 mile mark, so I'd change it along with tensioner pulley and timing belt.
2003 Dodge SRT-4
Old 03-12-2007, 12:59 PM
Re: water pump
yea thats what i was going to do change all that its about that time lol oh i was wondering is it hard to install a udp n cam gear
Old 03-12-2007, 01:06 PM
Re: water pump
The hardest part of installing a UDP is getting the stock crank pulley off. After that, you can bake the UDP in the oven at about 400-425 degrees and it will just slip on.
Cam gear is pretty simple as well.
2003 Dodge SRT-4
Old 03-12-2007, 01:14 PM
Re: water pump
for the cam i have to mess with the timeing after im done right not for the udp
Old 03-12-2007, 01:20 PM
Re: water pump
Correct!
2003 Dodge SRT-4
Old 03-12-2007, 04:58 PM
Re: water pump
thanks alot bro
Old 03-13-2007, 08:48 PM
denisond3 denisond3 is offline
Re: water pump
I use a wooden dowel rod, about 3 ft long & 1/4 inch diameter. I put one end of the rod onto the part I want to listen to, like the water pump housing or close to it, and I put the other end of the dowel rod against the mastoid bone, just behind my ear. This way I can listen for bad bearings, etc. Ideally you would listen to the bearing before it begins to go bad, so you can tell what a good bearing should sound like. Of course be Very careful with the end of the stick near the moving parts.
