Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 03-09-2007, 05:02 AM
GT11 GT11 is offline
Sent from Buick......... Over heating RoadMaster
I let it run for about 1/2 hour. With the cap off the rad fill tank, it just keeps getting hotter and hotter until it just starts boiling out the fill tank. I even tried to vent any air at the vent screw on the tstat housing. New tstate. Temp gauge rises with water temp and will get about one mark from the red. At that point I shut her down. The second larger fan motor on the drivers side will never comes on. With the A/C or Heat on max it does not matter. To see if the larger fan worked, I put 12 volts to it directly from the battery and it did run. As the vehicle was running I jumped the larger fan with 12 volts. Now with both fans running the vehicle still overheated in about the same amount of time.
Two problems with this vehicle. One, overheating and two, the larger rad fan does not come on.
I do not have a manual on this vehicle so if someone describes a component please let me know where it is located and what it looks like.
Thanks guys
GT
Old 03-09-2007, 11:03 AM
crazy Jim's Avatar
crazy Jim crazy Jim is offline
Re: Sent from Buick......... Over heating RoadMaster
non functioning water pump, if we knew which engine you had someone cold tell you where to locate the WP....
master airframe mech/shadetree auto mech/30+ years experience
current vehicles:
'02 Impala LS 3.8L
'02 Trans Am WS6 LS1 6spd
'99 Grand Am SE 3.4L
'71 Cutlass SX 455/TH400
'04 YZ450F
'07 Kona Garbonzo (dowwnhill mountain bike)
Old 03-09-2007, 10:09 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
According to his post in the Buick forum it's a '95. So that would make it the LT1. Here's a link to the original thread:http://www.automotiveforums.com/vbul...d.php?t=678687
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
