Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Old 03-08-2007, 09:25 PM
mlsias mlsias is offline
Question Low Coolant Light-97 Olds Achieva
97 Olds Achieva: My low coolant light stays lit all the time. But my coolant level is not low-plus the engine temp gauge has never gotten any hotter. I did replace the coolant temp sensor.
Any ideas?
Old 03-09-2007, 09:23 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Low Coolant Light
either the connection of the coolant sensor are dirty or thier is air bubbles trapped on the sensor.
Might check those out.
1999 Grand Am SS 3.4 OHV
Old 03-10-2007, 02:56 PM
rroberts6781 rroberts6781 is offline
there should be a reset button in the fuse panel on the driver side. If you hold the button down for a few seconds it will clear the low coolant light. Now if the light comes back on during the next time you drive, continue with checking the sensors and connections.
Old 12-08-2009, 02:36 PM
sowseyed505 sowseyed505 is offline
Re: Low Coolant Light-97 Olds Achieva
your float inside resevoir is stuck. either remove res. and clean by filling with hot water and shaking or replace w/new one.
Old 10-26-2011, 06:51 PM
olds97ach olds97ach is offline
Adding to this thread, found it through a google search. Hoping that it will help others if they run into the issue.
Replaced heater core, then 2 weeks later replaced radiator.
Low coolant light stayed on, never went off.
Checked with a engine diag tool, no code. Reset battery and removed connections. Kept Adding coolant. Same result.
After 3 weeks and about 1200 miles later give or take, the light went off and on for about a day, and never showed up since. Could have been air or sediment, but in my case also it was just patience.
Old 10-26-2011, 08:22 PM
Tech II Tech II is offline
Some interesting answers.....
There is no reset button by the fuse panel, for the low coolant light....that reset button is for resetting the oil change light, and in some cases the low tire light....
What has happened, is what sowseyed505 said....the float is stuck in the sensor.....however, this only happens when reservoir gets really low....just adding coolant doesn't "unstick" it.....take the end of a screwdriver handle and tap the reservoir in the area of the sensor(don't hit the sensor itself)....the light usually goes out....
If the reservoir was NEVER low, then you could have a bad sensor or connection as xeroinfinity stated....disconnecting the sensor should make the light go out(this checks the circuit).......
