Go Back   Automotive Forums Car Chat > Pontiac > Grand Prix > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here (for both Pontiac Grand Prix and Oldsmobile Intrigue)
Old 03-08-2007, 03:46 PM
03impala9c1 03impala9c1 is offline
steering wheel radio control installation
so my switches took a crap the other day and i got new ones off ebay. pulling the old ones out was pain enough because the wires are too short connecting to the switches but how do i get the new ones in??? i cant get anything between the switch and the steering wheen to slip the harness into the switch do i have to take apart the steering wheel???
Need help!
thanks
jeremy
03impala9c1
View Public Profile
Send a private message to 03impala9c1
Send email to 03impala9c1
Find More Posts by 03impala9c1
03-04-2007, 11:34 PM #2 03impala9c1 vbmenu_register("postmenu_4648513", true);
Re: steering wheel radio control installation
WELL... I FIGURED IT out by myself... in case anyone here needs to know... heres how to change them...
1. wiggle out old switches.
2.pull and disconnect old switch.
3. unscrew rear cover plate of steering wheel (2 torx head screws).
4. pry lower part of plastic back.
5. Locate a black wire that runs around the wheel from the hole where the switches were located and runs to the bottom of the steering wheel.
6. There is a hook that holds the wire onto the corner eof the steering wheel.
7. pull the wire loose from around this hook.
8. pull the wire harness outward out of the hole in the wheel.
9. plug in new switch.
10. take an allen wrench or something of the sort and pull the wire back through the hole and wrap the wire back over the hook.
11. push new switch back in... test... and tighten the rear wheel cover back on and your finished!
***5 WAYS TO KNOW YOUR A REAL MECHANIC***
1. YOU HAVE NO IDEA WHAT THE TERM "ANTI-SIEZE" IS.
2. ADD-A-WRENCH (EXTEND-A-WRENCH) IS YOUR BEST FRIEND
3. YOU KEEP A 3 FOOT PIPE IN YOUR TOOLBOX TO PUT ON THE END OF YOUR BREAKER BAR AT ALL TIMES
4. YOU HATE MECHANIX GLOVES AND USE THEM AS RAGS
5. EACH TIME YOU TAKE A SHOWER YOU SPEND MORE TIME CLEANING GREASE FROM THE SHOWER ITSELF THAN YOU SPENT CLEANING YOURSELF!!
Old 08-19-2010, 08:50 PM
BIGPROFITT BIGPROFITT is offline
Send a message via Yahoo to BIGPROFITT
What year Grand Prix is this for? I have a 2004 Grand Prix and need to remove the right side control.
