Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-08-2007, 12:01 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Question Which Shift Kit?
Hey guys! Which shift kit would you recommend to put into a stock, fresh 700-R4? I want a firmer shift, and I want 4th gear to engage at WOT. I already know that B&M is kinda generic. Any thoughs? Thanks in advance!!!
Old 03-08-2007, 12:14 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Which Shift Kit?
In my experience, the B&M shift kit softens up the 2-3 in a way that's kind of weird. It actually starts to shift crisply, then flares. About 10,000 miles into the current trans in my car, there seems to be no harm, no foul so far.
The WOT OD is a spring behind a spool valve. This doesn't come with the B&M kit. The TransGo kit is more expensive, but much better, so get it.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 03-08-2007, 03:48 PM
PeteA216's Avatar
With the TransGo kit would I be able to make the OD gear act as a fourth gear so that it'd shift into fourth at WOT? Also, out of curiosity, does it allow you to change the shift firmness through different springs and what not, or is there a just a set default that they give you as with the B & M?
