Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 03-08-2007, 10:42 AM
stormy1226 stormy1226 is offline
96 mazda protege wont start
I have a mazda protege 1.5L SOHC engine that overheated. I replaced the head gasket and had the head milled. The timing is correct and compression is good. The engine turns over but wont start. I got the car started with starting fluid. I replaced the fuel pump. I disconnected the rail from the block and turned over the car and I got a good spray from the injectors. I have good spark. Could the computer be bad? I am out of ideas. Please help.
Thanks
Old 03-08-2007, 02:00 PM
mazdatech177 mazdatech177 is offline
Re: 96 mazda protege wont start
if it starts with starting fluid but not without, it sounds like a lack of fuel situation. make sure you dont have the fuel inlet/outlet lines mixed up on the fuel rail. the one coming off the fuel filter at the firewall is your inlet line
Old 03-14-2007, 04:21 PM
Doug Tatham Doug Tatham is offline
Make sure that you put the crank postion sensor ring on in the right direction. I put mine on facing in instead of out following a timing belt change and had the same symptoms. It sends an incorrect position to the computer and you don't get the fuel in the cylinders at the right time. Starting spray will make it kick over since it isn't going in through the injectors. The position sensor ring has a painted spot on it and is a flat ring that looks like a gear with a tooth chipped out.
