Old 03-07-2007, 11:41 PM
superman3405 superman3405 is offline
headers vs manifolds and motor mounts
What is better exhaust manifolds or small tube headers? I have the manifolds right now and with swaping engines I may replace to headers if they are any better.
Also motor mounts for a 1972 Chevy, how do you get the things off is there a way to unscrew it direclty from the engine without removing the entie mount?
Old 03-08-2007, 10:33 AM
777stickman 777stickman is offline
Re: headers vs manifolds and motor mounts
Headers are a nice addition although in some cases they make changing the plugs a real PITA. Motor mounts should have a long bolt running front to back that comes out. Once the motor is out you can remove the mount from the side of the block.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-08-2007, 12:09 PM
also between the engine mount and the engine there is a rubber filler, it is pretty worn so I am going to replace it. What is it? I do not know how to look for it at stores without knowing what it is called
Old 03-09-2007, 06:10 PM
The rubber you're seeing is part of the motor mount that's attached to the block. Go to your local parts store and ask to see a motor mount for your truck and you'll see what it looks like.
57 Chevy 210
