Old 10-06-2002, 07:48 PM
civic89dx civic89dx is offline
Send a message via AIM to civic89dx
Question need help, problems starting
hey guys, my 89 civic is having trouble starting sometimes. it doesn't always have trouble, but it has a few times. the battery is fine. i was just wonderin if u guys had any ideas what else it could be.
Old 10-06-2002, 07:50 PM
kris's Avatar
kris kris is offline
Off playing with fire.
When it doesnt start, do you here a click, when you turn the ignition on?
Old 10-06-2002, 09:41 PM
no, i don't think so
Old 10-06-2002, 09:48 PM
kris's Avatar
Well, the most common starting problem, is your starter. There are a few ways you can tell if its going out. The first, easiest way, is listen. When its not starting, try and listen if you hear anything from the engine bay.
The second is to pull it out, and have it tested. That takes about 20 minutes, and a trip to the parts store.
Old 10-06-2002, 09:50 PM
branman_crx_guy's Avatar
branman_crx_guy branman_crx_guy is offline
Send a message via AIM to branman_crx_guy Send a message via Yahoo to branman_crx_guy
Main Relay
If ur cars not starting, its gotta be the main relay, thats the only problem us 4th genners have . Just kiddin, sry about that. Seriously tho, have u checked ur ECU for codes? Sounds to me like something with fuel, but not sure wat, i bet someone with actual knowledge will reply soon, im just here to make it so u dont feel despondent
Born 2/19/85: Thats right ladies, the BMan is Legal!! ;-)
Totallin My 89 CRX Si: +$2700
Buyin It Back From Insurance: -$50
Buying a 90 CRX Si: -$2200
Gettin to start over with more money and knowing i screwed insurance w/out trying: Priceless
It doesn't matter if you win by an inch or.........wait, thats been said already. On the road of life there are passengers and......no, thats been done too. Dang, all the good sayings have already been said, ohwell.
-BMan original
Old 10-06-2002, 09:52 PM
OOOOOH OOOH, yeah, that sounds good too. I knew smart ppl with take over soon, u actually got there b4 my comments, good job :ylsuper
-BMan original
Old 10-07-2002, 09:57 AM
Brad McCoy Brad McCoy is offline
First we need to define "Not Starting"
1. Starter turns engine over, but engine will not start - could be:
A. Electrical problem
B. Fuel problem
2. Starter does not turn engine over - could be:
A. Electrical - could be:
a. Wiring - are all connections related to battery and starter in good working order? Sometimes you must take connections apart and clean them.
b. Manual transmission car? If yes, the clutch pedal must be fully depressed in order for the starter motor to turn the engine over.
c. Manual tarnsmission? Clutch switch could be bad or disconnected.
d. Bad starter
I am sure there are quite a few more things to check, but these are a few that came to mind.
Hope this helps!!!
Problem starting latorawilson Impala | Impala SS 8 04-29-2011 03:14 PM
WONT START, need help fig. out what the hose is 4 mrs.k.m.ashby Grand AM 0 02-12-2011 05:07 AM
need help asap starting problem greasemonkeyfl Problem Diagnosis 2 06-26-2009 10:11 AM
need help on starting/idle problem fullthrottle13 GTI 1 03-10-2007 09:40 AM
Need Help With Starting Problem!!! paintbb84 Golf 1 02-25-2004 05:14 PM
