No headlights(High or Lo beams) after installing new low beam bulbs
Hi All,
Not sure what's happened here. I put in new headlight bulbs over the weekend. I didn't check them to see if they worked or not at the time. What the heck they're new right? Now I have no headlights whatsoever. No dims and no brights. When I pull the lever to switch to brights I get nothing. No headlights, no blue Bright indicator on the dash. I'm pretty confident it's not the new bulbs themselves since the brights don't work either. No blown fuses... What else should I look at? The switch on the column under the dash? Help!
CD 1991 W41 #142 1989 Caprice 9C1 1997 C1500 1997 Bonnie SE 1998 Olds 98 LS Recently updated: http://forums.b-body.org |
Re: No headlights(High or Lo beams) after installing new low beam bulbs
try putting the old ones back in and see if they work.
What year Astro? I highly suspect the hi/lo beam switch- look for melted contacts- if it is an older Astro.....- or rod that is out of adjustment.........under dash on steering column
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
Well after spending about an hour with the volt meter and taking what seemed like half of the van apart... It was the switch in the dash. Replaced that and the dimmer switch, just as a precaution, and all is well.
Is it possible to replace the switch without removing the steering wheel and disengaging the airbag? How difficult is the repalcement? |
I replaced the one in my 98 safari without removing the wheel but it wasnt the easiest thing to do lots of things to remove and tight places to work but i managed look at the switch to see how it goes on..
what year you have? |
Are looking at the dimmer switch or the multi-function switch for that price? The dimmer switch should cost no more than $50 for the part.....
When you pull the lever to dim, it pushes a metal lever which runs down the steering column and triggers the actual dimmer switch. The dimmer switch is not locacted right there where the stalk mounts....
