Old 03-07-2007, 12:01 PM
Whitworth Whitworth is offline
79 Ford F150 - idle problem
Truck runs good - sitting idling, tack nominer will drop slowly when warming, and will cause truck to stall out. What's up with that? Do u know?
Old 03-10-2007, 05:51 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: 79 Ford F150 - idle problem
I'm new to Ford's, I just bought an 89 f250. I didn't get any help to my problem on this forum. You should head over to www.ford-trucks.com They will help you!
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 03-16-2007, 01:52 AM
Torch Torch is offline
The chokes on those were designed to slowly drop the idle as the engine warms up, check your idle speed screw it should be on the same side as the throttle rod/cable is on.
Turn the idle screw in a turn or two this will raise the idle speed, hook a tachometer up to the ignition coil, once the engine is warmed up adjust the idle screw until the idle is where it should be.
