Old 03-07-2007, 10:41 AM
HawgHunter74's Avatar
HawgHunter74 HawgHunter74 is offline
What does tighten an additional 55 degrees mean?
97 chevy silverado cylinder heads. Tightening sequence says tighten all to 22 lbs the tighten the short bolts an additional 55 degrees, the med ones 65 degrees and the long 75 degrees. How much of a turn is that?
A mouth will say anything...
Old 03-07-2007, 02:16 PM
wrparks wrparks is offline
Re: What does tighten an additional 55 degrees mean?
A full turn is 360, half turn is 180, 1/4 is 90, and 1/8 turn is 45 degrees. So, just a bit over 1/8 of a turn. But, I've never seen things referenced like this. Where did this come from?
Old 03-07-2007, 02:53 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
What engine?
When turning in degrees they make a tool with the degree reading wheel on it.
Check your local parts place tool store or a auto tool dealer.
Are you using new head bolts?
And double check your specs on it.
MT
