Old 03-07-2007, 10:31 AM
Fred D. Fred D. is offline
2000 T&C Rear leveling suspension
HI,
I would like to replace my leaking NIVOMAT Self leveling shock absorbers
with some regular Monroes. Besides the shock mount bolt being a different size. Can I do This without any problems ??? I have being given many different stories by dealers.
Thanks for your help in advance,
Fred D.
Old 03-07-2007, 04:00 PM
Bernard Feltzer Bernard Feltzer is offline
Re: 2000 T&C Rear leveling suspension
You could do that if you want, but the leveling system will no longer function.
Use the heavy duty shocks, fatter than the stock regular shocks.
Old 03-07-2007, 08:44 PM
vipergg vipergg is offline
Wink Re: 2000 T&C Rear leveling suspension
Originally Posted by Fred D.
HI,
Fred D.
What you don't want to dish out $300-400 a piece for shocks . I don't understand .. :-) I'm in the same boat down the road , have them on our 2004 .
Old 03-10-2007, 09:29 PM
xj31 xj31 is offline
I was told that the ones with the nivomats have weaker leaf springs,so if you put regular shocks,it is supposed to sag in the back,esp.with a load.This was from a chrysler technical training class a few years back.I don't know if this is true though,because I have never seen it done.It makes sense because those shocks do carry a lot of the load when they pump up.
Old 03-11-2007, 07:31 AM
Definetly not your normal shocks , if take a look at them they are huge and look like they belong on 2500 heavy duty pickup .
Old 03-12-2007, 09:29 PM
Those shocks are not normal.They have some kind of valving inside that pumps them up when you go over bumps when you have a load on them.If you take the load off,the back of the van sits high up and they pump back down when you drive.
Old 03-29-2007, 11:11 AM
sak22's Avatar
sak22 sak22 is offline
USACMRETVET
Fred D....
I have a 97 Town & Country LXi with the Load Leveling Suspension and replaced those shocks a while back when they went bad with a set of Monroe Heavy Duty shocks. There was absolutely ZERO modifications... They fit in there perfectly. However... Even with the heavy duty shocks, the van still sags a bit in the back under a load (kids, lots of suitcases etc...) With no load, it's just fine... sits a little bit higher than level. Thought about replacing leaf springs, but I can live with the slight droop under load. Most of the time, the van is not under any significant load anyway so I'm not concernde about it. Hope this helps.
2008 Honda CR-V EX-L SE- Glacier Blue Metallic
2007 Honda CR-V EX-L SE- Nighthawk Black Pearl
2003 Honda CR-V EX- Chianti Red Pearl
2002 Chevrolet S-10 LS- Dark Cherry Red Metallic
1989 Chevrolet C1500 Silverado- Custom Black Cherry Metallic
"The Black Beauty"
Old 04-16-2007, 02:34 PM
briksay briksay is offline
The Nivomat shocks are definitely expensive from the dealers. Those shocks supply a specific amount of lift to the rear of the vehicle. Replacing them with regular shocks will make the vehicle sag like 500#s of rocks are in the rear. You can buy a new set of Nivomats on Ebay for the Chrysler minivans for $250. That is a lot less than the $700 to $800 at the dealer. At $250 for a set that is cheaper than converting when you include the new heavier springs.
Thanks
Brian
