Old 03-07-2007, 06:10 AM
PlayStation3 PlayStation3 is offline
Gains
hi, if i where to buy a bigger amp then my speakers can handle i would use the speakers rms in the formula to find the proper volts that i need right.
Old 03-07-2007, 08:33 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Gains
Depends on what your goal is
If your goal is to send the speakers their rated power when you hit the headunit's clipping point, then yes. If your goal is to set up the system so that the amp clips at the same point as the headunit, and you just use common sense to keep from blowing the speakers, then no.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 03-07-2007, 05:23 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Gains
I always buy amps rated higher than my speakers RMS
Old 03-07-2007, 05:53 PM
Re: Gains
ok so with this formula which should i use if i don't want to blow my speakers.
( don't mind the numbers) ( the speakers rms or the amp's)
The formula is sq root of Watts x resistance(ohm load)
400 watts by 4 ohm is 1600 then we find the sq root of 1600 which is equal to 40
We now know that 40 volts is equal to 400 watts.
This 40 volts will be found with the DMM
Old 03-07-2007, 08:21 PM
sr20de4evr's Avatar
Re: Gains
yes, theoretically
'01 Black Sentra SE
'05 Silver WRX STi
Old 03-08-2007, 05:51 PM
Audio Guy
Re: Gains
that's the gist of it ....... certainly a good place to start, just remember that you're output will be pretty low doing it like that.
Old 03-08-2007, 09:32 PM
Re: Gains
will the speakers i want to use are 110 rms and the amp is 150 that i want to use.
Old 03-09-2007, 05:58 PM
Audio Guy
Re: Gains
that shouldn't be a problem if you watch the volume
