Old 03-07-2007, 01:27 AM
eXcelon eXcelon is offline
Question A/C Air Condition Please Help Me
does anyone know why the front a/c blows warm air and the rear a/c blows cold air ? i seem to be having this problem. thanks for all your help and time.
doug
Old 03-07-2007, 06:11 AM
jsinton jsinton is offline
Re: A/C Air Condition Please Help Me
Sounds like the heater controls don't disengage from you front blowers. I never investigated how this works but I assume it works on vacuum lines. Probably either your controller is bad or you have a leaking vacuum line.
Old 03-07-2007, 01:31 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Here's a quick fix you can try. It recalibrates the ventilation control system:
"Start the van and turn on the blower. Simultaneously push the top and bottom wiper buttons on the left side of the ventilation control panel for 5 seconds. All the lights on the panel will light up. Then two lights on the left side will alternately flash for about two minutes and you'll hear the ventilation modes cycle. When just the top light on the left side slowly flashes push that button and you're done. All lights should be out and you should be back to normal. Restart the van a few times and make sure. This is the ventilation control/AC cool down calibration test and it resets the ventilation system computer."
If that doesn't work for your 02 try one of these:http://www.allpar.com/fix/codes-climate.html
If this doesn't fix it you probably have a bad blend or mode door actuator, ventilation control panel (computer is in it), or wiring between them.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
