Old 03-06-2007, 10:49 PM
91 S10 In Red 91 S10 In Red is offline
Send a message via MSN to 91 S10 In Red
Speedometer Not Working, Low Oil Pressure, An Fuel Running Out At 1/4 Of A Tank HELP.
  1. Speedometer Not Working Period...
  2. No Oil Pressure At Idle But Good Pressure When Driving...
  3. The Classic Problem Of Fuel Running Out At 1/4 Of A Tank...
Any Help Would Be Greatly Appriciated.
The Truck Is A 1991 s10 2wd extended cab truck with 4.3, Automatic.
Old 03-07-2007, 02:46 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Speedometer Not Working, Low Oil Pressure, An Fuel Running Out At 1/4 Of A Tank HELP.
First thing first.
Get a manual oil pressure test gauge and post back readings cold and hot.
Manual or digital dash gauges?
Any codes stored in computer or check engine lights?
MT
Old 03-07-2007, 11:32 PM
manual gauges, check engine light comes on but mabe 5 miles down the road not when first started. turn truck off it go's off then comes back on 5 miles down the road. also i think check engine light cause is catalitic converter wire is not connected.
Giddy Up
Old 03-08-2007, 08:54 AM
MT-2500's Avatar
AF - Advisor
We need the oil pressure reading with a manual test gauge.
MT
