Old 03-06-2007, 08:57 PM
toolhead toolhead is offline
Send a message via AIM to toolhead
mass air question
i just bought a 1992 3000gt twin turbo with slight electricle problems. well to sum it up the battery blew up and melted the mass air. now for the question. will non turbo mass airs work with the turboed moter? and if not will a mass air off a 94 and up work on a 92? thats all thanx for the help...any other imput on the car will be appretiated also.
Old 03-06-2007, 10:26 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: mass air question
yes, the non-turbo MAS will work on the turbo cars. actually, the MAS for all years of the 3000GT/Stealth are interchangeable.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 03-06-2007, 10:33 PM
thanx for the info...ill have that car up and running in no time now
