Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 03-06-2007, 08:29 PM
pirates4ever pirates4ever is offline
2002 Sentra GXE with weird no heat issue
I'm looking for assistance and hope you guys/gals can come through for me.
I've got a 2002 Sentra GXE with 76K miles on it. Three weeks I got an SES light on the dash and the car started overheating. I went ahead and had the thermostat replaced at a local shop. At the same time I also had the plugs and fluids replaced.
Now for the last two weeks I've had intermittent heat but the car will occasionally run very hot, but not over heat. I'm not loosing any coolant which leads me to rule out a gasket leak. The only other symptoms I'm seeing are a slight shudder on cold start which resolves itself very quickly and the perception of a stiffer gas pedal on acceleration from a stop. I'm not sure if those are directly related or not.
I'm struggling with what would be causing the intermittent heat and running hot. I'm willing to replace the thermostat again, but I'm not sure if I should be looking elsewhere.
So, fire away! Thanks in advance for any and all assistance.
Old 03-07-2007, 02:03 AM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
Re: 2002 Sentra GXE with weird no heat issue
so the blower sends air into the cabin its just cold air or it doesnt send anything at all?
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
Old 03-08-2007, 11:41 PM
That's correct. Most of the time it's barely warmer than outside air temperature. But then it has days like today where it works fine. Meaning, the heat blows very and the engine doesn't run hot. Other times, it will run hot and suddenly start blowing heat and the engine will cool off.
Old 03-09-2007, 05:28 AM
have your coolant flushed, not drained, but flushed under pressure
