Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 03-06-2007, 03:24 PM
StephenCF StephenCF is offline
95 Bonneville Window Problem
In my 95 Bonneville the window control will not work at all. It doesn't go up or down.
The automatic locks don't lock either. They use to work but now they won't now.
I checked the fuses and none seemed to be blown. Other than the switch or an electrical short what could be the problem?
Old 03-06-2007, 04:36 PM
Mickey#1 Mickey#1 is offline
Re: 95 Bonneville Window Problem
On some models the door locks & windows share a common ground. Check the driver's side ground bus for corrosion. The fuel pump also grounds here so I'd check it sooner rather than later. Here's a pic to help you locate the grounds.
