Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-06-2007, 08:39 AM
lesab92 lesab92 is offline
1996 Camry shop manual
We purchased a 1996 Camry wagon last fall. It's in nice condition with under 60K and we would like to take good care of it as previous owner. Any suggestions on a good shop manual? Any suggestions on maintenance at 60K? Will the timing belt need to be changed even though the mileage is low? I would like to do a brake job myself. Are brakes easy to do on a car like this? Sorry for all the questions and thanks in advance for any help.
Old 03-06-2007, 01:40 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: 1996 Camry shop manual
There is a generation 3 (1992-1996) Toyota factory service manual stickied here that is available for free downloading:
http://www.automotiveforums.com/vbul...d.php?t=497839
As far as the timing belt is concerned, it is due for changing at 60,000 miles. Brakes are pretty easy to do, but if this is the first time you are doing any brake work, I would suggest having someone with some experience in doing brakes help you with the job.
Mike
Old 03-06-2007, 10:53 PM
Thanks Mike! I've always wanted to try and do a brake job. Guess I should leave it to the pros.
Old 03-06-2007, 11:28 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
For maintenance requirements, see the following link:
http://www.edmunds.com/maintenance/M...ing.feature..4.*
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 03-07-2007, 08:50 AM
GSS123 GSS123 is offline
do the brakes yourself, follow directions in your shop manual and do one side at a time. That was you have the other side to look at for reference on how things should go back together. You will have a lot of self satisfaction when you've finished the project.
