Old 03-05-2007, 11:32 PM
taylor1354 taylor1354 is offline
Re: Transmission Problems!
I have a 93 taurus. While driving, the car will drop gears (ie 3rd to first, or neutral) and then after some tricky footwork with the pedals, it wil snap back. this is becoming very frequent and may land me in an accident soon. is it the transmission going or could it be the TPS?
Old 03-06-2007, 04:42 PM
TaurusKing TaurusKing is offline
Re: Odd shifting of transmission
Get a code scan done, there may be some trans codes related to incorrect gear range and or others.. these codes may not turn on the check engine light... you need obdI scanner, they cost around 30 bucks or so, and are easy to use.. Your tricky footwork with the pedals sounds interesting, exactly what is it??? You may be in for some expense, I hope not.. some trans shops will diagnose for free, or small fee, they can scan for codes and run some pressure tests, use a locally owned reliable non-major trans shop, I'm staying polite..
Old 03-07-2007, 12:40 PM
Millermagic Millermagic is offline
Could it be a VSS going bad?
- Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers -
As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee!
Old 03-07-2007, 01:26 PM
seasonalskier2006's Avatar
seasonalskier2006 seasonalskier2006 is offline
Send a message via AIM to seasonalskier2006
autozone will check and diagnose the codes for free. they can tell you exactally whats up.
Old 03-07-2007, 06:14 PM
i have to rev the engine, let it fall then rev it less, let it fall, then rev it really high so that it will change gears and i dont get rear ended.
Old 03-08-2007, 03:15 PM
Is it like stuck in neutral?
Old 03-10-2007, 07:15 AM
Huney1 Huney1 is offline
Put some Lucas in it because at this point anything is worth a shot.http://www.lucasoil.com/products/dis...tid=2&loc=show
Easy to find at most parts stores.
